Staring up at the underside of my XJ I see a lot of the results of the good ol' Iowa highways in the winter, salt...water=rust. Floorboards suprisingly not that bad but the frame rails...eek. There's no way to fix it by plating over, only way would be to cut from the top or bottom and explore to find what is good and what is gone to replace. This got me thinking, why not just cut away the frame rails completely and build a traditional frame for the XJ?
What I'm thinking is, gut the XJ, interior, drivetrain, glass...cut the framerails off of it completely so it's flat underneath and repair any rust in the floors. Build an interior/exo cage, tube fenders in front, tube enters through the firewall and right into cage...that type of thing. Attach the cage to the XJ's body in several points, roof, pillars... adding a lot of rigidity to the body itself. The floorplates for the cage would be extra large footprint and this would become the bodymounts underneath, isolated by poly/rubber bushings of course. The frame could be constructed out of a variety of materials, possibly 2x4 or 3x4 tubing. This might help with a lot of the stress cracking typical of heavily abused unibodys, make future mods a lot easier and be a challenge that's for sure.
Just throwing out an idea, what do you think some of the bad points might be?
