Doubler behind an Aw4?
dingo151
Moscow, Idaho
Anybody running a doubler behind an Aw4? I was thinking about putting one in but wondering if its not a good idea... heard rumors that the XJ doesn't have enough brakes to stop itself then.
I can tell you the xj brakes will stop a 4to 1 tera low. Much more than that its gonna be a neutral show. Which isn't bad, I run a 4speed atlas with a Dana 44 front and it will stop but it feels like its twisting the ever living sheet out if the whole rig
17"and rims bigger breaks, frame stiffeners. And if your clocking everything flat adding a cage would be a good idea..
I hope your not running the stock Dana 30 front and whatever you have stock rear?
