dont flipout
OK. If I understand what you're asking, and assuming your 91 is the same as my 94, here goes: The male end is a flat orange plug with two prongs, one of which has a notch in it. It comes from the control stick (combo turn signal) on the steering column. It might be routed through the steering column or not depending on whether it was factory installed or retrofitted (I added mine). To find the female connector, find the wiring loom where it comes through the firewall directly above the accelerator pedal. Trace the loom out from the firewall a few inches and you'll find a branch terminating in a small flat female jack. Mine has a small white lever on one side. Insert the male end in so that the notch engages the white lever. Voila!. Hope that helps. Good luck.
Ray
Roads said:
Or maybe your just missing a brain.
That'll restore the hostility in the thread I'm sure.
