Dome Light Problems
Spearfisher XJ
The front dome light does not work, while the rear one does. This is weird because I thought they ran in a circuit? Bulbs are brand new, fuse is good. My best guess is a problem with the connection on the front light?
1988 4.0
Well, if they were truly ran in series, neither would work if one lamp failed, and you have one working so...
I guess my first step would be to take a meter and measure for voltage across the lamp contacts. If you don't have a meter, can you at least switch lamps and make certain the problem doesn't follow the bulb?
Next, get the wiring diagram and see how it should rally look, I think the downloadable fsm for the cherokee is only like $9. In the end though I think you'll need to either have or borrow a meter to trace it down.
