gw204
- St. Leonard, MD
Replaced the coolant bottle on my '88 4.0 XJ this afternoon in addition to the upper and lower radiator hoses and the heater hoses. Just want to make sure I have everything going to the correct places.
Long hose comes out of the t-stat housing and connects to the "T" fitting. One ouput of the "T" fitting goes to the top port for the heater core and the other goes to hte bottom port on the coolant bottle.
The other hose comes out of the engine and connects to the heater valve. One port of the heater valve (the one w/out the actual valve) connects to the top port on the collant bottle and the other port on the heater valve (the one that actually has the valve) connects to the bottom port on the heater core.
Do I have everything going to the right places???
Can find the drain in the block though??
Any hints?
I started the Jeep and let it idle for over ten minutes. The temp gauge never even came close to the 210 mark.
Thanks.
Brian
Thanks.
Brian
