disco d30 vacuum lines
Well yes I think they should be capped since you will still have vacuum coming through them. I have always wondered if a T connector with all three lines connected would still allow the 4X4 light to come on.
Yeah that's all nice and junk -- but it's far easier to get under there with a short length of hose and the engine at idle...
Shift the thing into 4wd and locate the tube that has vacuum -- now connect the short hose to the tube on the far end of the connector -- the dash 4x4 light should come on ! (if it doesn't try the other tube, it's been a while)... then CAP-OFF the qty=1 remaining tube.
You've restored the operation of your 4x4 light and don't have a vacuum leak ducted down to the UCA's body mount (not like THAT'D EVER get wet!)
