FatXJ
- South Range, MI
Well I finally overheated. Yesterday at the Marquette, MI run I got into the red zone. I shut it down and noticed my aux fan wasn't working. With some quick thinking I cut my fog light power wire and wired it to the fan and presto I had my fan again.
The problem is that the thing still overheated with the fan on. Then when I was driving home last night it would get well over 210 and then drop within 5 seconds down to 180 then a little later go back up. It repeated this several times. I am going to flush the radiator and put in a new thermostat this week.
My question is does anybody have any idea which temp sensor turns the fan on? I don't know why it wasn't turning on but it should have. So I was wondering if the temp sensor for the fan is different than the temp sensor for the gauge inside? My thinking was that the radiator was staying cool enough to not turn the fan on but the lack of coolant flow was keeping the engine much warmer. So if the fan temp sensor was in the rad and the gauge sensor was in the block then this would make sense. Any idea's, thought's, etc?
