Diff. Temp.
shapps13
Paxinos,PA
I changed gears in my Dana 35, from 3:07 to 4:10, and went with used gears. This is the first gear setup for me and got the pattern pretty good, have been running them for about a month and have changed the lube one time already. I have been adding Kal-Gard engine guard to the lube,it is a moly additive. I really don't have anything to compare the temp. to, never checked it with the 3:07's but after a 25 mile trip the diff is pretty warm. Is it because the gears are used, I set my pinion preload to spec. but set my backlash to the low side of the tolerance and preloaded the carrier bearings about .004 per side. Should I be concerned ? Any thoughts?
Thanks,
Bill
Thanks,
Bill
Any gear whine? That would be the biggest indicator and of couse finding excessive amounts for wear metal between oil changes.
BTW what's the Kal-gard cost?
Recently re-geared the D30 in mine.shop owner said as long as the temp stayed under 180* everything was OK,Temp on mine was 154* after a 10 mile run.Everything was set on the tight side.
Temp was taken with one of those IR gunson the housing at the pinion snout.
The 180* temp was the temp when the seals were to fail,where he got this number I do not know
Wayne
I'm guessing that the temp. is right around 150,I can hold my hand on it for a fairly long time,it's not so hot that I pull my hand off right away. I have a pyrometer on my multimeter that I will have to check it with. The KalGard is about $10 per 8oz. bottle from my friend who is a dist. here in PA. He runs a microsprint and uses this stuff in the transmission. He swears by it. I have also used it in the transmission of my tractor and it makes a difference. I will steal the XJ from my wife today and check the temp. after a 10 mile run.
Bill
Finally got to check the temp. today, and it maxes out at 134 F. This is after letting it sit about 10 min. after a 20 mile trip. As far as I can tell there was no metal in the fluid and the gears,although used,seemed to be O.K. with no sharp edges or chunks missing so far. Gear noise I would say is at a min., can't tell because of the exhaust, but it certainly doesn't have a howl when you are on the throttle or let off to coast.
Thanks,
Bill
Thanks,
Bill
i don't have anything technical to base this on, but that sounds just fine. heck, some places in Arizona and such have 134 as the air temperature
