Chancer
- Bonnie Scotland
Hi,
A while ago I overheated and seized the engine in a Ford Cargo rigid I use for carting my horses around in. After messing around and changing the head gasket I have managed to get her running, but roughly. There are two problems that are immediately apparent that I have to get sorted - the engine sounds like there's piston slap or knocking (I don't know the difference) going on, and the injectors are all leaking at the pipe join.
Could the two problems be connected?
What's the best way to stop the injectors leaking - is it a case of torquing them up more, or using ptfe tape or similar to plug the leak?
If the injectors aren't causing the knocking, what's the best way to diagnose the cause to the problem?
TIA.
TIA.
