BLKXJ33
- Cumming, Ga
Does anyone know of any diesel engines that will fit in an xj...without too much major modding. Thnx
oldmopars said:Volvo used a 6 cyl version of the VW Diesel. Its an inline 6 and looks about the same length as the 4.0l and not tall like the Cummings.
Nissan also made a 6 cyl inline Diesel, the Air Force uses them in Jeep Tugs. These are a strange looking Jeep. They have a CJ looking hood, but with Square headlights mounted in the fenders. The back is cut off and there is a heavy steel rear that has the tow hooks. They use a 1 ton rear and the front axle is just a hollow tube, no diff. However, they do have a Auto trans and a T-case, but it seems to only be used to get the low gear. The tugs top out at about 25 MPH.
This would be my choise if I were to go Diesel in an XJ, but finding one may be hard. Airports may also use them.
I just found one of the Jeeps on E-bay, here is the link:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2457663136&category=6280
or Item # 2457663136
Scott
WilliesTJ said:i've been thinking about the diesel option too, but am looking toward the liberty crd as a donor, it is similar to the 5cyl in the dodge sprinterr van and mercedes, as well as euro grand cherokees, pt cruisers, and caravans. the liberty setup will provide just about eveything from engine thru transfercase, already bolted together. otherwise i'm looking at the ford 6.0 powerstroke drivetrain, engine to axles, for my wrangler tj.
