I swapped the MAP sensor with a junkyard sensor and it's a little more stable, still wants to idle around 1100 but that's better than 1500. Won't know for a couple days for sure.
Go figure every engine was missing the ISC/IAC and the TPS.
That don't sound good but less than 11 ohms is OK when you get over 11 ohms by more then 20% fuel pressure could drop. Just jump it out, you don't need it.
Jump it out to see if it solves the problem, if it does then replace it. It's only to cut down the noise from the pump a little, older XJs never had it.
