90xjblue
- Yakima, Washington
I thought you might like that.
This XXXXing lower drag link bolt isn't working. I can't get it to stop spinning to save my life. That's all I need to have the axle completely installed. I did a couple back and forth rolls to make sure everything rolled right and that was ok. Once this bolt is tight I can put a cotter pin in everything and I'll be done.
I had the same probelm when i put a zj tie rod onto my xj. I used a c clamp to press the two bars together tight enough to get the castle nut tight. Stupid thing kept spinning till i put some pressure onto it so it would stay.
either that or you can have someone use a large pry bar to put pressure against it.
