Desperately Needed - 1/4" alum. spacer between brake booster & firewall
gone postal
I know this came on '95/96 XJ's and that's the system that I'm swapping into my '91. I don't know if newer years had this same spacer or not. If you have one, please PM me w/ a price shipped to 32084. This is the last part I need to do this swap.
I've seen the spacer mentioned as some have it..some don't...some need it and some don't.
I pulled one from a 1996 XJ. It had a foam rubber spacer as a SEAL...not really a spacer.
Have you tried to put it in to see if you need it??
At worst, you could use 1-2 washers per stud and mount it that way and do some foam sticky strips to seal it off.
I don't have one to sell but hope the tech maybe helps a bit.
Yeah, I know there is definetely a foam piece as a seal, but from what I've heard there is the alum. spacer and most say it's needed, some say it's not. I guess I'm just going to make one out of plywood and if I do end up needing it, I'll at least have something.
