foxwithsocks
- SouthFlorida
Hi guys
I have a 1992 XJ that I picked up from my dad's friend 2 years ago and have replaced various parts on. Right now, I'm working on trying to prevent death wobble from occuring, because I think I have some symptoms of it. For the past few months, I got a lot of front end vibrations around 55 mph and would continue until about 60, 65. Sometimes, if I took my foot off the pedal, let it get below 55 and then slowly brought it back up, the vibrations would either lessen or not exist until a higher speed.
I took the car into the shop the other day for a different problem and they rotated the tires for me and the vibrations seem to be reduced, but they're definitely still there. I read elsewhere and saw that there are several parts that may be loose that I should check (tie rod ends ? ) I don't know a lot about cars yet, so I'm not familiar with everything that should be checked, so I'd appreciate any help.
Also,
When I picked this jeep up from my dad's friend, it had been sitting around for a couple years not being used. I've gotten a bunch of parts replaced but I was wondering if there were suggestions on what else to replace. I'm hoping to replace them myself if I can. Off the top of my had, I've replaced:
I'm getting the muffler replaced, I found a hole in it. Also thinking about replacing all the wires since a bunch of them seem to be getting corroded. Anyway, this is getting real long, so thanks in advance for any help guys!
Also,
- Fuel pump and tank
- starter
- PCM (reason why it was in the shop
- O-ring on oil filter housing
- battery
- AC fuse
