dead XJ
luvdaxj
Sonoma
I've had a small reoccuring problem with my 91 XJ 4.0, where the engine would lose power momentarily. I replaced all fuel lines, fuel pump, filter, injectors, everything to do with fuel, it didn't help. This small problem became a big problem when my engine finally died and would not start again. It has spark, and it has fuel going to the cylinder. I took a wild guess that must be a sensor gone bad making the computer fire the engine in the wrong order. I was wondering if anyone has had this problem? I'm going to replace the crank position sensor tomorrow and see if it helps. any comments and suggestions are wanted. Please help.
