- Hammertown, USA
Tomorrow evening. Gotta get some work done so I can afford to pay my bills at SFR and Bishop Buehl on the new project car....
(which btw, will get steering with jam nuts)
another reason not to run Jam nut steering. Cal does. .!..!.
One races koh the other races a keyboard. I'm taking cals advice.
never had any issues with my jam nuts.![]()
once again, ask yourself. Why would IRO, a company known for being the budget cheap option, change their steering from a simple jam nut system to pinch bolts? something that is more complicated and more expensive.
my guess is they figured out what the OEMs and the guys like synergy and currie already knew. pinch bolts are more effective and safer in most instances.
Ruff stuff its beefy and the price is great
so you're telling me that a stamped collar, a bolt, a nut, and splitting the tie-rod and retapping/cleaning the threads is cheaper and less complicated than just having a nut? how is that possible?When you're buying wholesale and manufacturing in quantity pinch bolts aren't more expensive or more complicated. In many cases they are actually dirt cheap and simple.
I don't know what the reason they switched is, but I know if you're loosening a jam nut by hitting it on a rock it wasn't properly torqued to begin with. The problem with any large fastener is not the design, it's that people don't tighten them properly.
BTW, I built the car that Currie won the first and second KOH EMC with. John Currie himself did the steering and suspension setup, and it used jam nuts everywhere.
You're an idiot.
Because you're not doing any of that. You're buying it all from happy china co. who is stamping them out in the millions.
I like your backpeddle on currie though. You used them as an example for doing it your way, I just pointed out that they don't even do it that way on their own stuff, only on the mass production stuff you buy off the shelf.
When you're buying wholesale and manufacturing in quantity pinch bolts aren't more expensive or more complicated. In many cases they are actually dirt cheap and simple. I don't know what the reason they switched is, but I know if you're loosening a jam nut by hitting it on a rock it wasn't properly torqued to begin with. The problem with any large fastener is not the design, it's that people don't tighten them properly.
