dana 44 w/ true trac and 4.11's and 4.5" leafs
blondejoncherokee
sacramento
xj dana 44 rear with a true trac and i believe 4.11s but i need to count the teeth and divide to be safe.
i have all new brake hardware and some really good drums for it
480 obo
4.5" leaf packs... not sure of the brand, look like rustys, but not sure, bushings are great
160
with 1" greasable shackles
190
blondejon
this is not the same as the other part out jeep by the way, i actually have this on hand as of right now, the part out jeep is up in the air.
the 44 has 4.11s for sure
i believe the shackles are RE
the springs could be as well, ill post pics soon of everything
also adding:
6" skyjacker lift coils
90$
4 shocks for a 6" lift
70$
adjustable track bar and bracket
bracket looks just like kevins offroad modified bracket
85$ for both
adjustable ucas with flex joints
80
still have the 4.5" leaves with 1" shackles
190$
ill sell the whole lift coils leaves shackles shocks ucas and trackbar and mount together as well
damn i wish i had cash, i need the leaf springs, and would love to have that axle
ill sell the leaves coils ucas trackbar and mount and shocks all for 490.
all youll need is lcas.
the coils look good. the entire lift looks fairly new.
ill be posting pics asap.
the rear shocks are charged the fronts are just the regular doestch tech 30$ cheapos.
the uppers are for a long arm kit and are supposed to mount in the lca spot. they are angled inward slightly because of that. so they can only be used with a long arm kit.
alright got more goodies now!
sye kit for a 231, came off a 231 J , not sure what years itll fit, ill take pics soon
has tail housing, shaft, yoke, and all the gears left on the main shaft and snap rings too.
150
long arm kit without belly pan
lowers need a belly pan type mount made, the rig they came off had something welded onto the frame rail, if you can weld these are great for you.
uppers mount to lca mounts
both have flex joints and poly joints.
look good
160
teraflex greasable shackles in great shape, very beefy
35$
blondejon
i have no idea what the long arms are. thats why im going to post some pics. maybe someone on here knows
I pm'd you about the shackles. Anyone doing a parts train from the East Bay?
as of now the second set of shackles are sold(the ones not on the leaves)
