Dana 44 Rear housing with 4:10
Maxxrus08
So Cal
I have a Dana 44 Rear axle from an '87 Jeep Cherokee XJ. I pulled it from a junk yard to use in my Jeep Wrangler but never installed it and now I don't need it since I have a Cherokee now. The axle is clean of all brackets and spring perches. It is only the axle housing with factory 4:10 gears installed. No shafts, bearings, or brakes. I also have 4:10 ring and pinion and carrier for a Dana 30 HP reverse cut front axle that I will throw in. Asking $300.00 No Trades please. Need the cash for XJ upgrades. :repair:
Give ya 100 for it...
A complete drum to drum and bolt in d44 is worth what you are asking.
Coming from someone who has 3 up here in wi. Just letting you know, it's worth what it's worth. It isn't worth what you want in that condition. I can buy new carrier, gears, and install kit for what you are asking, maybe have $450 into everything with junkyard d44 from MJ or xj, and won't have to get shafts to boot
I know that it seems high but here in Ca. the D44 is not easy to come by. And i also know that people will always try to come down in price which i am fine with but not a complete low ball price. And its a matching set of 4:10 gears.
I apologize. I guess I was way off on this and i should have researched more before i bought it all myself. I will drop it to 200.00.
I withdrawal my 100$ offer....
