Dana 30 woes
Sonic16
Oakland
Ok, so I’m on my 4th pinion seal in 6 months. I keep installing them and they keep leaking. I do all the things: lube the inside, use rtv on the rim, torque the nut. The pinion itself also does not wiggle. All that and the damn thing keeps leaking. Any suggestions regarding what I might be missing here?
Do you need a new yoke? Have you micro-polished the seal surface?
BTW, are you using a new crush sleeve with every install?
How are you achieving the proper pinion bearing pre-load? Are you using a new pinion nut with loctite?
Gotta be something else going on here, I just zapped mine off with the impact, popped a new seal in, zapped it back on good'n'tight and haven't leaked a drop in 30k miles. I know its highly unlikely but maybe the pinion shaft isn't true anymore.
The LP D30 uses crush sleeves.
Thanks for all the feedback. I'm not using a new crush sleeve. Is there a way to test the current one to determine whether it is bad?
A few other folks suggested a clogged vent tube. I'm going to try that as well.
Crush sleeves are considered a "one use" item, that's why getting the proper pre-load is so critical.
