citizenatlarge
- Virginia
1. '92 XJ
2. Engine- 4.0
3. Transmission- Automatic
4. 4WD / NP231
5. This XJ has no lift and stock diff gearing. All tires are the same size, and was not put into 4WD anytime within the past year.
Hello. It's been a while.. I need some advice please. This '92 Jeep Cherokee XJ decided to have her front u-joint on the rear drive shaft, transfer case side, seize up and cause some nasty looking damage. I think the u-joint was just as old as the truck and eventually locked up due to lack of maintenance on my part. ie-not greased.
I plan on replacing the driveshaft asap, but the weather here doesn't look good anymore for the next length of predictions in the weather reports.
So, to the questions: Have any of you seen this before, and is it at all safe for mild to and from to work and back? Some highway speeds along the route, but those can be avoided. My thinking is along the lines of what's less stressful to the joint?
I also flipped the driveshaft around so this weak point is at the rear differential, so that if it does fail, it won't act like a pike into the ground.
Thanks to anyone that can help.
I have 13 images total and instead of making a really long post, I'll link one, and then the album from my imgur account if that's ok.
http://imgur.com/a/6Rmxx <---Album Link
2. Engine- 4.0
4. 4WD / NP231
