Lowrange2
- Abbeville, SC
Meh, you'll be ordering coil-overs within a year.
Finally, become amember so you can bask in the glory of red-named greatness, and roll down the street smokin indo, sippin on gin and juice!
1994. And yeah Tim I am not driving it. Took it to the car wash 1 mile away this morning to rinse the engine so I could see things a bit more clearly and spot fresh leaks, but that is it.
I'm concerned that I'll put new HD cables, a fresh battery, etc, and end up causing damage to them, so everything is on hold until I pull the Alt and have it bench tested.
So yeah. I'm tempted to get an HD cable pack if there is one that replaces those grounds also. I know my + and - cables are damaged/frayed, and have open frays, not touching anything, but unsheathed at the terminals.Hi, I'm Dave, sounds like an overcharging problem.
First thing is check all the connections, at alt., battery, battery ground on block. Make sure they are all tight and no corrosion.
The main causes for overcharging are a grounded field wire, field terminal or connectors.
If all that checks out good then yes it would be the PCM (powertrain control module). It would be internally grounding the field wire continually. And it would need to be replaced.
I'll stand by my "add an auxiliary gauge and run with it" post from OEM Tech.
What you're getting to the gauge is always lower than what's getting to the battery (longer circuit to the gauge)-- so if the gauge reads higher than whats at the battery, the gauge is A.F.U.
If you don't use the cigarette lighter in the dash, you can use that circuit for an aftermarket volt meter-- it's much shorter of a circuit than the dash gauges and switched with the ignition to shut off with the key. My dash gauge reads 4.5V below the actual system voltage and the aftermarket volt meter is almost exact using the lighter circuit.
