D30 truetrac
1990JEEPXJ
San Diego
recently removed my truetrac to have a grizzly installed. it works perfectly. i bought it new less than a year ago. jeeperjohn did the install. it is for 3.73 and numerically higher gears. good piece for those with the NP242 that want to retain the use of full time 4wd. theyre nearly $400 new. looking to get $240.
Sorry this exact one is not. I did someone a favor and traded them mine for one that is for 3.55 and down. Which I doubt many people here would want/be able to use. So I do have one but if the other one I had worked, this one will not.
I believe you can get "thick cut" gears for a 3:55 and below carrier. Check with one of our sponsors about that.
Hmmm... How much do you want for the 3.55 and down true Trac?
FYI. There are no thick cut D30 gears. Once a long time ago they did have for a very short run Low Pinion CJ D30 thick, but those are no longer and would not fit a high pinion anyways.
Could of swore that the ring and pinion out of the Dana 30 rubicon gears were thick gears up to 4.10's... Maybe I was misinformed but I was told I can use the 4.10'a on the stock carrier
I think you may be referring to the rubicon D44 axles. they do have the thick cut gears. but i do not think the rubicon package uses a D30 axle. sahara and such use the D30s, but not the Rubicon.
The rubicons are All D44's and Yes ALL rubicons are thick cut gears, both the TJ and JK.
There are NO thick cut Rev (high pinion) D30 gear sets...
