DM_MKV
- Albuquerque N.M.
1996
4.0l
150k miles
5 speed
Sorry to create another "misfire thread" but after reading all other search results and trying those fixes I am still getting a code. The misfire is barely noticeable at idle/driving.
Things replaced:
Cracked header with APN header and new gasket.
Crank shaft position sensor.
TPS
Sprak plugs, wires, cap and rotor.
Fuel filter
O-rings on injectors
Took care of original code which was misfire in cylinder 1, 3, 6, after 50 or so miles code came back with misfire cylinder 3. I am going to check the wiring to the injectors tonight as well as the spark plugs for fouls. I will post a pic of my findings.
Other issue that may help someone more knowledgeable then me:
Car has problem starting on first try take about 10 sec of me cranking the key to start it. I don't like doing this so I crank it once and the turn it off and crank it again and it starts right up.
Thanks for the help.
Derek
4.0l
150k miles
5 speed
Things replaced:
TPS
Fuel filter
Derek
