cuting guage holes in a stainless dash panel...
sidriptide
nobody of any consequence
i'm setting up a new dash panel in a YJ this week. aside from the radio and heater control panels which will be easy. i need to cut 3 nice 2 1/16" holes for the guages. we're using 1/16" stainless sheet steel. i'm sure there is a nice tool for punching the holes neatly but thats beyond me right now i think. i'm gonna try to use a 1 3/4" hole saw in a drill press on a peice of scrap to se how it goes and use a carbide burr in a die grinder to open it up .. also thinking i'll see how the plasma works and finish with the burr as well...
any other ideas?? this is for a customer's Jeep so the final product is important.
Carbide grit hole saw in the proper size (or a bit smaller,) or knock it out using a boring head in a mill, I'd think. You should have an easier time finding a carbide hole saw (I see them at the local hardware store up to about 4",) and you can use that in a drill press.
5-90's got it...you don't want to try that with a toothed hole saw. Stainless will just eat that up. An abrasive one really would be your best bet.
The 'best' tool for it would probably be a Greenlee punch:
However, like usual, the best tool for the job isn't cheap. If you can afford to go up a little in size, here's a *great* deal on a 2-1/4" one:
http://cgi.ebay.com/Greenlee-730-Kn...ryZ73118QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
and a 2" one:
Look around and you might find the one you're looking for...although if you need something fast, the carbide grit saw is probably your best bet.
yeah i knew something like that must exist.. but i expected them to be part of an elaborate expensive set... i'll have to see if they make 3.5" as well for my speedo and tach. thanks!!
They actually make different shapes too (rectangles, squares, etc) which work well for mounting switches and stuff like that.
To buy them new and in a set, they're incredibly expensive.
FWIW - the carbide die grinder doesnt work so well in stainless... the stainless hardens as it gets hot, and then the carbide grinder stops cutting...
done thatl... :twak:
I just used my plasma cutter.
I practiced on some scrap, then decided to make a template out of of some hardwood I had lying around. The bezel's on most gauges are not all that wide, so you need to practice first.
You may find that using some aluminium plate is easier.....
I used to have a Greenlee set, but the a*hole who owned it wanted it back!
Rick
