NCCherokee
- Anderson, SC
Originally when I first lifted I did the old cut and fold. Looked ok if you didn't look close. Decided that in anticipation of moving up to 37s from 33s in the next year, is like to widen the rears and clean it up a bit. Looked at a bunch of threads, T&Ts low cog XJ build, Goldrush on Pirate, stumpxj on here. All went about it a bit different but ended with basically the same result.
I have a rigidco rear bumper with end caps for my cut n fold lower rear quarters, so they extend up to the wheel well. This limited how much I could cut back. However I'm trying to keep the interior as in tact as possible, so I didn't want to section and widen the inner wheel wells, because I wanted the trim to fit back correctly.
I used a combo of an angle grinder and a jigsaw to separate the body from the wheel well. The wheel well consists of an inner piece and an outer piece. I left about a 1" lip of the outer sheet metal all the way around so that I can use that as my base to weld onto when I patch it. I can't weld, so I'll meet up with a buddy in a few weeks to do that.
Still trying to decide if I want to use 1/4" rod or brake line like T&T or just weld the two pieces of sheet back together. The eventual plan is for JCR rear quarter armor/light boxes, so I know I'll have to trim those. Depending on if they would fit, I'm considering Napier flares vs jeeptubes tube flares welded onto the JCR armor.
Onto the pics
I'll get more pictures once we start working on putting it all back together.
Onto the pics
