Pardon a long post on a simple question, but:
I like the Cherokee for its utility. It's just a practical vehicle that can also do some pretty respectable off-roading - and maintain practical DD values.
I can't leave stuff alone, though, so I'm working on a build plan that keeps all the Cherokee design goals (AC, Heat, windows & doors, street manners & off road capability) but more so.
When I'm done, I'll take it to the body shop and have them re-badge it "Anasazi" - the ancestral native americans that were here before the modern Cherokee, and a bit rougher around the edges.
I've got the inside bedlined. Rear ZJ discs. Mild lift. Bigger tires. In the works: WJ knuckles, SYE, stiffeners, overhead console, the list goes on...
THe point I'm making is this: If you are going to build your rig to be what YOU want, instead of the Factory Original, make a plan and name it something else. You do a lot of road trips? Get a compass. Lot of mudding? Some trick OEM looking / integrated mudflaps. Dig hotrods? 8 ball shifter. Drive barefoot? Fuzzy pedal covers. Drive with heavy winter boots alot? Maybe space the pedals so you don't mash 'em both at the same time. Too tall? Lower the seats. Etc.
Think of what you like about your rig & add to it.
Nobody else's personal touches are going to be Your personal touches.
