Cummins Comanche?
So I got a reply...
Ok so that looks like a Diesel but that is not a 60 I have ever seen. :explosion
That motor looks sick, but that definitely is not a D60!
That is totally a D60. :rolleyes:
I'd still rock it... Until the 35 blows up.
ax5 behind a CTD.. hmm..
i was thinking the same thing. everybody seems some worried about the D35, itll be just fine. the power will never even make it back there, the tranny will explode at the thought of dumping the clutch
THats definately a Cummins and thats definately a D35! :roflmao:I see stuff being replaced in the near future if someone on NAXJA buys it!
anyone else notice this "The truck will need a transmission. It's common, cheap, and easy to find"
the ax-5 didn't make it!
It would be nice to see his cooling fan setup. He must have some pusher fans tucked in there somewhere.
I've spent a few miles behind the wheel of a Cummins 4bt in a CJ7 with a nv4500 and 300 tcase plus a rear d60. That Cummins couldn't put the torque down fast enough to hurt that d35 on the street. If you could somehow (trailer) hold the MJ back, then yes it would blow up everything around the Cummins. Oil pan clearance would be an interesting thing to see.
Hank
