I run a 93 Sport with a 4.0L HO, AW4, and it has always cranked over for what I thought was too long before fireing up. The engine is a low mile unit in tip top running condition, the battery voltage is good. I have replaced the wiring from the battery to the starter and alternator with 2 gauge without much difference at all. The starter's amp draw isn't out of line, although that is the only thing I can see, unless there is some problem in the ignition circuit. Any one have any ideas on where I should look next? Any help would be great, thanks.
