Ecomike
NAXJA# 2091
- MilkyWay Galaxy
OH-K lets make this 200% perfectly transparent gentlemen.
Battery voltage, 12.7 before cranking at the battery and at the starter.
Voltage while cranking, with a new fully charged battery and new starter, did the same crap the 1 year old battery and 1 year old starter did, to be PRECISE, it had 9 volts at the battery and 9 volts at the starter while cranking for 1-2 seconds. By the end of the 1st second, the starter was still fully engaged and busting its ass under full load trying to turn the forking engine, and it did not turn after the first second, between the first and 2nd, second.
We tried it twice, The engine has something forking jamed up inside.
What are the possible things, and likely things that can cause it to do this IN THE DAMN ENGINE?????
This. Was getting good voltage now 10?
Also have the person check the wires and terminals on the starter itself for good connectivity and no corrosion. Although new starter should've fixed that issue.
Still question the helpers skill
