Crane Cams #753901
markaboo929
Mooresville,NC
Hello I am building a stroker 4.6 engine and plan to use the crane cam 753901 BUT it is advanced 5 degrees,I want a little higher rpm band so i was thinking of bringing it closer to 0 ,more or less 2-3 advanced degrees using an adjustable timing set.Has anybody done that to their's?
No, but I used the identical spec Crane 753905 cam in my original stroker build and I was very happy with the powerband with the cam installed as Crane intended (5 degrees advanced). Unless you spend a lot of the time holding the engine at higher rpm, I suggest you do the same.
Thank You Dino...I apprecieted the responce to the emails we had previously.I did get the Crane Cam due to availability and speaking with the engine machine shop-they do all race motors-on Crane brand...anyways.Dino what rpm/cruise speed where you felt the power band real good?I do however cruise at 75 mph @3000 and in 4th around 2500-2700 45-55 mph.Very rarely do I cruise under 2300-2500 rpm.It has been a constant debate in my head that needs clarification..I do trust your judgement very heartedly...:sunshine:
I kinda had to be honest with myself when planning it all. Truth be told, I don't race my Jeep on a daily basis and most of it is cruising so building a compromising mid range engine wasn't such a bad idea.
This is in my daily driver-the machine shop is only doing the block work-bore and hone .020" mill the deck .020" , install cam bearings and furnace clean to a new looking block,not just hot tank it.Yeah i am thinkin install cam as is,which was my original plan...which leaves me pondering to cam bearing failures as to weather or not they were installed correctly-gradual smaller taper to inner cam bearing the front being the largest-my machinist is aware how they go in.He has my cam so if it isnt right he would match the bearing clearence to fit...as the factory manual states.
The torque was spread pretty evenly from 1000rpm to the 5200rpm rev limiter and I loved it. Your cruising rpm is right in the meat of the powerband.
