- Seattle, WA
I think the hand tools are fine. The jacks are crap - I've had 2 start leaking in the last 2 years. But at least they replace them for free. That's good enough for me.
It's not a question of "I think" they are crap. I got my first set of Craftsman tools in about 1958. I still have them and to place any one of them next to today's production its appalling how cheep and poorly designed the current ones are.
Take a 1958 box wrench as an example. The steel is superior, the geometry of the wrench is superior. I've never broken or worn one out and I've used these tools professionally at least half my life. Using superior steel the tools are thinner, they reach into tighter spaces and move a nut or bolt farther with each swing. The angles are better so that the teeth engage the bolts squarely so slipping off is minimized.
Today's wrenches are fat because of the cheep steel more steel is needed to provide some strength and they still bend and break.
Don't even get me started on the current crap-ass ratchets.
I'll buy their stuff if it's made in the USA, most hand tools. If it's from China, and I can't get it from the USA within my budget, then I will head on down to HF, because it's probably cheaper.
OK, here's the deal.
Most people don't know this, but Craftsmen and Matco are owned by the same company, a HUGE global conglomerate that goes by the name of DANAHER.
Danaher also owns the companies that make Allen tools, Jacobs Brake systems(Jake Brakes), Tektronix, Fluke, and a ton of companies that will be familiar and a lot you have never heard of.
If you don't believe me, just go to danaher.com and poke around. You will be amazed.
All Danaher cares about is maximizing profit by driving down production costs and keeping quality at the bare minimum acceptable level.
If they can find a way to trim 2 cents off of a product they will do it, because in the long run it will mean millions of bucks of bottom line profit.
Craftsmen Tools are focused on the home mechanic, but the marketing makes you think otherwise.
Matco tools are focused on the pro mechanic.
That's why the quality differs so much.
Older Crafstmen tools are very much the quality tools of legend.
Current Crafstmen tools are.......well ......just crap.
Both Matco and Craftsmen are manufactured overseas (guess where).
Tried to return a rachet and they gave me a rachet rebuild kit in a plastic bag. They said they do not replace the rachets anymore.
