Eagle said:The bolts holding the torque converter to the flex plate are a LOT smaller than 14mm. So are the bolts holding the flexplate to the crankshaft.
I think the reference we used here was to the head size, are you referring to the shank? The shanks on the TC/Flexplate bolts are M10x1.5, and should be abount 14mm long (more than this will bottom out, had that problem previously). The heads on the dealer bolts (I used p/n 34202497) are place-bolt style, and require a 15mm socket.
I just replaced some "substitute" bolts I had with the dealer ones a couple of days ago, so was just in there. And the red Loctite was pretty stiff...
