Ecomike
NAXJA# 2091
- MilkyWay Galaxy
Yep. That's why I use the tape trick.
IIRC last time I started the bolts in by hand, and removing them by hand, I did not use a socket except to torque them and loosen them. My fingers, thanks to recently raging Rheumatoid Arthritis, are not what they were 4 years ago.
hasta
The time before that on this rig the transmission was on the shop floor, ready to swap trannys, so it was not an issue, and I was tired and rushed and did not slot them.
I have already drilled the holes larger to boost the stock CPS signal, and I will slot them, thanks for the reminder.
I may cover the hole first with duct tape this time, start the bolts in, remove the duct tape, then slide the slotted sensor on, then tighten her up.
Thanks for all the great suggestions!!!
