- Rainy side of Washington
Sounds like a fuse for the O2 heater could make a pretty decent "first mod" on a new Renix XJ then.
There, fixed it.
I'll give 'er a shot tomorrow, if it's still where I left it.
Thanks
Repeat your process w/ the front o2, then the cps, then tb sensors, then injectors, etc. When you repaired the wires, did you inspect them down the line from the break to see if any copper is bare?
Steve, F20 powers the ASD relay. You could remove the relay and see if it still blows the fuse, if so it is something downstream of the relay shorted whether wire or component. The ASD relay powers the injectors, the 02 heaters, ignition coil and alternator. Disconnect components one at a time to find the short. To save on fuses rig a test light into the fuse socket, if it glows as brightly as when hooked across the battery there is a short present.
All the wires in the affected circuit are the same color. I would disconnect everything in my list that runs off that fuse all at the same time. Then turn the key on, another blown fuse equals wiring fault.
New discoveries today: Front O2 doesn't seem to be problem. Disco'd and still pops fuse.
Pulled power lead to coil, still popped.
If I turn key to on and leave it, I can put a new fuse in, and it won't pop. If I crank engine, it pops.
Key off, no voltage passes through fuse sockets. Key to on, and 11.8v (basically battery voltage, as it's getting a little tired, but that's what battery tested to) hits fuse socket, but for only a second or so, then drops to 0.0v.
More laying in the slush underneath revealed the two wires from my tranny (AX-15), which I assume to be for reverse lights, touched exhaust and melted one side of male plug (part of the harness, not the switch).
On the surface, this doesn't seem to be part of the equation, but it is very new damage (as in just happened), and that wiring enters into the harness, which then runs forward towards the coil, and the coil is in the affected loop.
Interesting sounding gismo. Details?
Sounds like a cool way avoid tearing up wire looms in the search for shorts.
I think the wiring on the O2 sensor wires is where I suggested looking for bad insulation and a short earlier in this thread, but perhaps I was not clear enough?
:thumbup: Now back on the trails you go.
Even a blind squirrel finds a nut once in a while. j/k. That's the thing about shorts, they're always plain as day once found but without any visible external harness damage that can be a chore. The shortfinder is ok, it could be a little more accurate. It really shines when looking for shorted taillight wiring or similar that could be almost anywhere in the whole vehicle.
This is it: http://www.etooldirect.com/power-probe-model-ect2000-wireless-short-finder.html
Thanks, I will check it out.
Oh, and I don't know that I have ever run across a blind squirrel before, LOL.Besides, I think they smell the nuts out, LOL.
