- Henderson, NV
Just finished installing my new stroker in my jeep about a week ago and it seems to be running hot. I did the break in on the cam and during the break in she sat at about 215-220. This was understandable due to the high rpms with low airflow. However, Ive taken the jeep out and around and it runs at 220 with the A/C on and 215 off. When idling in a parking lot It went above 220 (stupid dummy gauge just pegs 260 once it hits 220). I checked the fan, its coming on full speed, and the mech fan feels good. I installed a 180* thermostat and a new water pump when I installed the motor. Radiator is the stock single core, it was fairly new before the engine rebuild, I did flush it really well before hand. Also, I still have all the shrouds on the fans.
Questions
Should I ditch the 180* thermostat and put back in the 195?
My current thermostat didn't have a bubble hole or anything, I don't know why, but I'm thinking maybe I have some air in the head.
Should I be looking into a 2 row radiator? is it worth the $$?
Electric fan upgrade? ditch the mech fan and go electric? Which ones?
Just dropped almost 3K on this stroker, so funds aren't in excess if you know what I mean. Because of that, I want to kind of brainstorm before I go shotgun some parts at it.
Living in Vegas, I want to make sure this thing doesn't overheat.
Specs are
4.6l
KB421 pistons
4.0 rod
258crank
.020 deck
9.0:1 CR
comp 68-231-4
.051 HG
stock fans
stock water pump
180* thermostat
stock radiator single core.
Questions
Specs are
4.6l
KB421 pistons
4.0 rod
258crank
.020 deck
9.0:1 CR
comp 68-231-4
.051 HG
stock fans
stock water pump
180* thermostat
