The cooling fan on my 97 will not shut off. I assume it's a sensor switch. Anyone have any input? Where is it located or any other possible causes.
Thanks in advance.
Mine was doing this recently. It was the relay sticking. Soon after (about a week later), it was stuck off and overheated
You may be able to tap on it and see if it goes off, but at $13 a pop, it may be worth just replacing.
Look under the hood in your relay box, located on the passenger side; and pop the cover off. Assuming the fan is still running, locate the fan relay and tap it with handle end of a screwdriver. If it shuts off, you have a bad relay. Just replace.
