jtszymano
- Aliso Viejo, CA
I see this many times...people say that the pinion should be 1-2 degrees below the output shaft angle.
What exactly does that mean?? ANd is the pinion and output shaft pointed up or down??Keep in mind I am referring to a stock set-up...
For example:
if the output shaft is 3 degrees, what should the pinion angle be?
Please explain the meaning of 'above' and 'below' when it comes to this stuff.
Thanks jTS
For example:
Thanks jTS
