ComChewy
- Central Florida O-Town
Com’s XJ-110
Well here are a few pictures of some of the items that I have acquired for the new XJ-110 Build that Jay Cooper and the Guy’s at Domination Chassis in Castle Shannon Pa are building and to be completed by (hopefully) Bantam’s get together in June………..
The Engine is a Liftout from a 2010 1500K (<40k mi) it’s an LS3 6.2L L9H w/ 6L80E
The Differentials Dana 60’s, the Front is from a King Pin F-350 DRW, and the Rear is from a 2001 W2500 w/ Disc Brakes
And it’s all going into this
The Chassis construction will be starting shortly, when it’s completed there will be some XJ sheet metal & 3/16’s sheeting hung from a complete tube chassis of a two box design with pneumatic suspension to drop it so I can get my azz in & out, then raise it so it wouldn’t get wet. It will also have exterior rub rails at the belt & roof lines so that immovable objects can be used to turn with, it will incorporate removable doors w/ tube replacements for those warm Central Florida days and A/C for the warmer ones……….
