Computer geniuses...HELP!! please!
roXJeepr
NAXJA Member #334
Knoxville, TN
I got cable ISP about 2.5 mos ago, the first 2 weeks everything worked awesome, but then something happened and now when I'm in IE I get real bad lag. Pages load pretty slow, scroll real slow, and when typing(like right now) my cursor moves one space about every second but no type appears until it catches up. For instance, if I type 2 words then wait for the cursor to stop moving, type will appear. If I don't wait for it to stop, it will keep moving but no type appears until it stops. I don't believe it to be my cable modem because I'm downloading at around 300kb/s. It lags even when I work offline, so I'm pretty sure it's in explorer.
If any of you have any clue as to what's going, PLEASE enlighten me!!! Oh, Ebay seems to be the worst. If I drag the slide bar at the right to scroll down, it takes about 5 or 10 seconds for it start to move, it's drivin me NUTZ!! TIA!
Dale
what OS are you running? How many things are running in the background (press cntrl + alt + del)?cant really help until we know a little more...
I'm running W98. 8 things in background. Resources are 80% free. 196MB RAM. Current on McAfee, no viruses detected. I'll go check that komando site now. Thanks guys.
I'd recomend going to windows XP. I had all sorts of problems with my compueter when I ran Windows ME..basically the same as 98. The XP upgrade handles your computer's resources MUCH better. Since I've upgraded...I haven't had any problems!!
This may sound stupid, but have you tried restarting your computer?
You can also try to free up some hard drive space...empty out your internet cache file, and clean out your temp files.
But I would definalty spend the $99 and get XP...You'll really be impressed on how much faster your computer runs.
I have a 700Mhz processor, and 196Ram. I was having the same problems you're having and more!! My computer would always freeze, and I'd get a message saying I'm dangerously low on system resources.
Hope this helps a little.
Rich
Okay well, i've had the same problem with internet explorer off of my 500 Mhz 256MB ram computer. Like right now i can't see my words that i typed for a second or two. it is really bad. even my mouse is lagging, but all of this is only in internet explorer. i run windows 2000 which is just about the same os as xp, except for offices and networks. I think it is internet explorer 6.0. I even tried to reinstall it and it didn't help.
Download a program called 'ad-aware' made by lavasoft, version 6.0. My guess is you have a ton of spyware running on your pc that is tracking your surfing habits, capturing credit card numbers and stuff like that.... Oh, after you install it download the update for it also, then run it. Delete ALL the files it comes up with. BTW, it's free. ;)
I don't feel like typing this all over again, for those of you who have broadband connections please look at my site and read the section under firewalls.
http://www.rjpsystems.com/homenetworking.html
You have to be NUTS to not have a hardware firewall in place, especially with cablemodems and if, god help you, you took the microsoft defaults and heaven forbid shared out a file system or hard drive, oh man, you are jjust asking for trouble.
Last time I clicked on 'network neighborhood' with the workgroup set to 'home' and then ' workgroup' on a customers cablemodem segment 75+ machines and their hard drives showed up.
When I first read your post my gut reaction was to run Spybot (same thing as ad-aware only I have had better luck with it). So I second Rich P try one of those programs first and see if it helps.
I downloaded Spybot and ran it and cleaned out a whole mess of stuff, found one virus and removed that file, but I see no difference. I'm guessing that some stuff in my registry has been changed. Any further advice? Thanks for the help so far.
Dale
Reinstallation suggestions
How long since you did any disc maintenance ?? right click 'mycomputer' 'manage' 'diskdefragmenter', let it run.
Right click 'my computer' 'manage' 'event viewer' look at your error logs.
Open your case, is the cpu fan running, when Intel processors overheat they cut down to half speed vs AMD which burn up :D Clean out the dust bunnies if you have never had it open with canned air. Myself, I would probably swap in a new power supply, seen them do funny things.
It is possible that enough damage has been done to warrant a reinstall. Copy important files to either a spare hd, cd-r, or dvd r. Do not bother copying software thats installed, it won't run just by copying it back generally unless it's a standalone that does not use the registery. Just copy your data files, word docs, xls spreadsheets, etc. Backup your email, if using outlook export your .pst file and put it on cd,
For best results reinstall following these steps:
Right click 'my computer' 'properties' 'device manager' write down all your drivers, network card, video card, sound card, modem model, etc.
Look at your system devices, see if you have an intel or via chipset, the first 4 or so listings will tell you, you may see something like '82443BX Pentium III', thats a 443bx chipset. Locate the drivers CD that came with your PC or motherboard, the motherboard will should have the manufacturers name, identify your motherboard and it's rev level.
If the MB is say an ASUS/Intel/MSI/etc go to their site and look up your model board, get it's specs. Download the latest bios, if it is an intel chipset go to intels site and download the latest chipset update, if it has an intel video driver pull that down also. Pull down the latest version of AVG antivirus put on cd-r, manually pull the newest signature update down from avg and store it with the avg so you can update the signatures file before you go back on the network, put the avg key they will email you when you download on a piece of paper for later use, NOTE:avg keys are 'case sensitive'. Unplug your cable from the cable modem to the network card, leave it out. Do not go back on the network untill you have antivirus software installed and updated. Make sure you have your win2k key handy before starting.
Boot from the 2000cd, delete the partition and recreate it, install.
After 2000 is reinstalled take the cd that came with your motherboard or that you downloaded and install in this order, chipset, disk drivers, video drivers but get that chipset in there first. Now go back to R click 'my computer' 'properties' 'hardware' 'device manager' and look for any uninstalled or unknown devices, tackle them next. Install the antivirus software and update the signatures. Put the network cable back in and bring the cablemodem/networking back up.
Go to windows update and do all the service packs and updates. From there it is just a matter of reinstalling all your software, it is a time consuming and PIA process which is why I have a spare hard drive and norton ghost comes in handy, once I have a machine where I want it I ghost an image to a drive with a norton boot disk, actually I have a norton ghost server running that I ghost to, that way if I ever need to wipe and rebuild I can do it in like 12 minutes. I had a HD fail last month, 20 days after a fresh install, got lazy and that one was of course the only one I had not ghosted, figures... Reinstalling difficulty is based entirely on how well you did the ground work in identifying your hardware and making sure you have the drivers for it. If it is a 'name brand' machine like dell it will have a drivers cd that should have all the drivers on it. If it's older then the drivers cd will also generally have older drivers and once running you should update them to newer versions, especially the chipset and dma drivers. Bios updates are also important, if the system won't recognize a 120gb hard drive thats a bios problem.
I think I pretty much covered everything.
One thing you can do before reinstalling, create and emergency repair disk, reboot the pc with the win2k disk in let it boot off of the cd, you can try the repair option but I have only had good results 1 out of every 9 times I've used it. It is a last resort before a resinstall.
Good luck and you really should get a hardware firewall next time. Those software ones like zone alarm and norton cause more problems and suck up an unbelievable amount of resources.
Rich,
Ummm, wow dude! I'm not real sure what some of that means. Is that the same as reformatting? I'm using W98, so does all that still apply? It's an older system I had built so everything is something-uji or -itsu. 400Mhz 196MbRam and 8GbHard drive. I'm 1/2 tempted to pull my disc drives out and can the rest of it and just buy a newer one...unless you wanna come over and do all that stuff for me :D
Its still sounds like a good machine, no need to scrap it. If you dont need more power I'd stick with it. But if you really want to get ris of it, I may take it off your hands for free or cheap :)
