Complete 98 4.0 and manual transmission ECU/harness
xeroOTG
floater
I've got a 4.0 I pulled from my 98 that I need out of the garage. It's got about 200k on it. I'm including the 136a alternator and modified bracket. It's also got a Melling high volume pump that I put in 40k ago. I'm also including the engine harness, fusebox, starter, and manual transmission ECU. I've got a cowl intake I'd consider including if you need one. I want $400 for it since I'm including the entire harness and ECU but I'd consider breaking it up or taking less money if your in a tight spot.
Sent from my Pixel 3 using Tapatalk
