cobra 75 CB questions
ricot83
NAXJA Member #1297
newington, CT
what is needed to make this thing work, i am thinking about getting one, also is a 4ft antenna ok to use?
What does the cobra 75 come with and how do you hook it all up to work and stuff?
The only thing you'd need is an antenna (4' will work, but you may want to mount it high up on the Jeep), a mount of the antenna, and depending on where you're putting it, an extension cable for the antenna. Instructions should be in the box.
Billy
Spend a little extra money and get the Wilson 1000 ant and mount. Mount it in the center of your roof for the best tranmission/reception. Once you have it set up make sure you TUNE your radio with a SWR meter!
