I just got in my new clutch slave cylinder. It was missing the bleed plug that my old one had, so I put the plug in the new slave cylinder.
I hooked everything up and went to bleed the air out of the line. I could not figure out why I did not get any fluid out of the bleed hole until I removed the slave cylinder and inspected the bleed hole only to find that it was not drilled through.
I decided to just push in the slave cylinder plunger a bunch of times to bleed out the air - which worked by the way. Question is, have they removed the bleed hole on the newer slave cylinders, or did they just forget to drill the hole??
I didn't open up the hole, but installed the bleed plug so I would not loose it. The clutch seems to work much better now and my shifting has improved. Funny thing, the bleed hole is threaded and the little side hole is there, it is just not drilled through to allow the air/fluid to escape.
Tom Dennis
atriot:
Tom Dennis
