prljeep
- Toledo, OH
90 MJ I6 4x4 MT 129k (AX-5 right???)
Two days ago, I went to drive my jeep to work and the clutch was acting weird. It had no feeling to it (a baby could push it in) and it would hard shift into the low gears especially (1 and 2) and reverse. It has recently gotton colder here from say upper 50's at night to upper 30's. The problem still continues-
I assume my clutch isn't burnt out- only because the RPMs do not go out of control when I accelerate (IE the clutch is not enguaging).
With that said- I am assuming it has something to do with hydralic system...????????????? The FSM says use Dot 3 brake fluid in there...is that true?
Could a low fluid/oil level in the tranny cause the hard shifts....
Where do you all suggest I start the investigation?
