Ecomike
NAXJA# 2091
- MilkyWay Galaxy
I have a custom 1985 diesel jeep (as gas 4 banger in another life), that has a nissan SD-22 power train, diesel engine and 5 speed manual transmission with an MC/SC hydraulic clutch.
Over a decade ago I installed a heavy duty clutch-pressure plate system after rebuilding the transmission. Now I am partly disabled with rheumatoid arthritis and my legs and knees are no longer strong enough to push the clutch pedal more than 2-3 times...But I can operate regular brakes, and new car clutches (tested a ford fiesta last week, and it was easy to operate). I confirmed today that the problem is the HD pressure plate spring and not anything else in the system.
The SC on the transmission is a near exact match area wise to the Jeep, and the jeep MC is a near exact match for the Nissan truck the diesel came from. So the hydraulic pressure at the pressure plate is very close to OEM.
One obvious choice is to try an OEM pressure plate/clutch package.
The other is to make or find a custom vacuum booster operated hydraulic clutch MC assy, or anything that is available in the custom world to make the clutch pedal easy to push. Until I install a weaker factory pressure plate, I will not know if that will be enough so I am working on a custom mod idea now.
I need ideas, links folks!!!! I can not be the first person to have this issue.
I do not want to give up my 34 mpg diesel Cherokee!!! BTW it can be push started, so it is EMP proof LOL.
Thanks!!!!
Thanks!!!!
