Chrysler 8.25 experts. U-bolt style yoke upgrade.
Airsmitty
Newhall, CA
Hey folks! I've got a 91 XJ (4.5"ish franken-lift, locked front, sliders, 32" KM2's, etc) with a c8.25. I had a U joint let loose on the freeway about a year ago and wipe out the little nubs that keep the U joint centered on the axle yoke. I jimmy rigged it to hold tight with some cut up radiator hose clamps smashed underneath the straps. This has been working surprisingly well(many wheeling trips, survived Moab, freeway driving), but I still don't like it and I'm always nervous driving it at speed.:explosion
It has the old-school shorter "collared yoke." I've seen how the newer yokes can be drilled to accept U-bolts, or kits that are made that way. Does anyone know if these will fit my older c8.25? I know the the yoke altogether is a bit longer, but is the spline length the same?
