- NE Texas
Alright, this is not exactly XJ specific but It might be useful for XJ owners aswell..I have Come to the conclusion that the Torque-converter is going bad in my ZJ, I am a D.I.Y.'er And plan to purchase everything i need tomorrow after i get the jeep back from the Trans shop (full diagnosis)
Torque converters, I have found everything from Factory OEM replacements, to Refurbished units.. To Upgraded Higher performance Converters.
I found one on Ebay for $199+s&h, Here are the "Specs"
Or should i stick to a Stock type replacement? what is all this "Stall speed" talk about?
:thumbup:
Would this be good for a Daily driver, that see's alot of street abuse (1/8 mile runs) that also see's alot of Slow trail usage..Level 2 High Stall Performance Torque Converter
Original Core Return Required
Perfect Upgrade for Daily Driver Stock or Slightly Modified Vehicles
-Brake Stall Speed Increased 400-800 RPM Over Stock
-(Typical Cars have stock stall of 1500-2000 RPM)
-Improved Off The Line Acceleration
-Improved 1/4 Mile Times (Up To 3/10 Second Faster!!)
-Improved Drivability
-Tig Welded Impeller Vanes
-Tig Welded Turbine Vanes
-Burnished and Polished Impeller Hub
-Verified and Inspected Turbine Hub and Splines
-Verified and Inspected Bearings (Updated Where Applicable)
-Verified and Inspected Washers (Updated Where Applicable)
-New Piston Dampner Seal (Updated Where Applicable)
-New Input Shaft Seal (Updated Where Applicable)
-High Performance Lockup Clutch Friction
-High Performance Custom Milled Stator Assembly
-Custom Machined Impeller Housing with Reworked Vanes
-Internal Clearance Lowered To Insure Higher Efficiency
-Mounting Threads Quality Inspected
-Computerized Robotic Sealing Welds
-TCRS Computerized High Speed Balancing To less than 5 grams
-Runout Tolerances of less than .005
:thumbup:
