mikeswrangler
- Norwell,MA
Ok all you chevy guys (if there is any on this board, haha) I have a 91 2500 with the 5.7. Once it is warmed up it runs like crap, bad accel/sputtering, nothing smooth about it. Check engine light comes on and off. These were the 2 codes that were pulled up and I checked online and found this info. Now is closed loop for the oxygen sensor during first start up of a cold motor, or while running at operating temperature. I figured closed to be at operating temp, but im not positive. I used to have a maxima and I know knock sensors used to go on those and were problems and the motors would run like crap but never experienced it. Whats your take on the codes. Replace the o2 and knock sensor only like 70 bucks.
Codes:
43 The ECM did not detect a knock signal during near wide open throttle operation, or the knock sensor voltage was above 3.62 volts or below 1.44 volts for 0.5 seconds.
44 Oxygen sensor voltage was under 0.2 volts for 50 seconds of closed loop operation.
Thank You!
Codes:
Thank You!
