carlton989
- Dallas, TX
Hello everyone,
Old member, got away from Jeeps for a while but recently picked up another XJ and need some help with engine codes. Quick run down...bought a 2001 XJ Sport, 4.0, 4wd, auto, and 165K. Got the Jeep for a project and the price was too good to pass up, so luck would have it that I am now having issues with it Check engine light was on solid when I bought it and the oil pressure gauge was maxed out (previous owner said it needed an oil pressure switch and a camshaft position sensor replaced).
Now to the real problem. The 3rd time I drove the Jeep, it started up, ran rough and the check engine light is blinking until I shut it off (limp home mode I believe). Had autozone runs the codes and here are the 6 codes that came up...P0300, P0301, P0304, P0306, P0456, and P1494. I believe that the P0300, 301, 304 and 306 are misfires in cylinders 1, 4, and 6 (can someone confirm this?). Should I start with new spark plugs or is there another route I should take?
The P0456 and P1494 are vacuum leak codes (I believe). Can someone confirm these? Where should I start with these?
Jeep is not a daily driver, so it doesn't have to be fixed right away. I am not a mechanic, but I don't mind getting my hands dirty and saving money on not having to have a shop repair it.
Any insight would be greatly appreciated as to where I should start.
Thank you,
Will
Thank you,
Will
