i also have a 72 charger se. I have bad vibrations in the car, i think that the engine mounts are ok, could it be an unbalnced driveshaft? what else? the raer end fluid is fine.` thanks everyone!
Other tech. I'm sure one of the mods will find it soon enough tho Where in Buffalo? I was born at the Deaconess and then moved to Rochester. Then AZ. Now CA in the Marine Corps...
Last car I had that did that had lost a weight on the driveshaft. It was actually easy to see. Crawled under and looked at the shaft. Was a cleaner spot shaped like a rectangle where the weight used to be. Had a driveshaft shop look at it.....they rebalanced and problem was gone. They wanted to make a whole new shaft but I couldn't afford it. If you do this you might as well change the u-joints at the same time. It is possible for them to cause minor vibe problems, I'm told.
