- Minneapolis, MN
Check out www.firestik.com for all the antenna info you will need. See the FAQ and Tech sections. Firestik and Wilson are the best brands of antenna. No Ground antennas just never work very well. How about alongside the console or under the glove box. I used some 1/8 x 1 flat steel to make 2 legs that go up from the floor to the console. Bolted the radio mounting bracket to the legs and screwed the legs to the floor for extra support.. I put the antenna in the middle of the roof. Remove the dome light or overhead console for access to the bottom of the roof. Powered from the battery with fuses inline.
